dkmc
- Jan 13, 2002
I have a V5 VMC been around a few years, considering a retrofit on it.
The DC Spindle is only 5HP and 4500 RPM
which is a bit lean and slow for todays tooling.
To make it a worth while project, I think it needs to go to at least 10HP maybe 15 if a motor will fit in there, and 6000 RPM.
So my question is, before doing the 'try & see' test, would the spindle bearings self destruct at 5000 or 6000 if the orig. limit was 4500?? Provided they are in good shape to begin with.
I also suppose back then (1980) they didn't intend the spindle to run -at- 4500 for hours at a time.
Speed & HP is a major issue in retrofitting older iron.
dan k
dan k
