Hi,
There's a 1995 Mazak VTC-20B available where I live and I was thinking about purchasing it. I know it's a very old machine, but I don't need to make any advanced parts and its capacity would be ideal for me. The problem is, my current workshop is not very big. The biggest problem is the ceiling and the door. The door is about 250x250cm (~98"). The machine is specified as 270cm high and 290cm wide (~106" and ~114" respectively). The ceiling is at 290cm high (~114"), so it's only a bit higher than the specified height. So now I have a few questions:
1. I'm guessing height is specified as the maximum height with the spindle up. Does anyone know how high it is with the spindle down? Or how low it can be without taking the whole thing apart? I would use 4" high skates to move it to the workshop.
2. How much space would I need around the machine for maintenance?
3. How much space would I need above the machine? Is 7-8" of clearance enough? Or will it cause me troubles?
I guess in a nutshell I'm asking if it's just too big of a machine and if I should just give up or would it work?
