Mazatrol - HELP
Results 1 to 5 of 5
Thread: Mazatrol - HELP
    Oct 2016
    AUSTRALIA
    13
    Default Mazatrol - HELP
    Hi guys,
    So i have a pre-machined casting that I want to face from the OD to ID direction, but its not at the Z0. front face. Its 14mm in from the front face.
    So basically the part has a 45mm diameter that starts from Z0 and goes to Z-14, then up to 103mm diameter.
    There is only 0.5mm on this face (which is too much for the WNMG to face from the 45mm out, so I want to face it from the 103mm dia down to the 45mm diameter.
    I have faced the Z0 front face no problem, and turned the part the conventional way using COPY, but I want to face that z-14 face from 103mm down to 45mm. It will be quckier, quieter and expend tool life. I have tried many ways but couldn't get it to work.
    Any ideas ? And thanks !
    Oct 2013
    Hartford, CT
    266
    170
    103
    Are you saying you want your cutting passes to go along the X axis instead of the Z axis? You need to use BAR FACE or COPY FACE to do that.
  3. Likes Philabuster liked this post
    Jul 2006
    Arizona
    4,645
    18529
    4433
    CPY FCE Start X 103mm, Start Z 12mm, Stock X 1mm, Stock Z 1mm,
    1seq X 45mm, Z 14mm.
  5. Likes kevin66, xa-mont liked this post
  6. #4
    Oct 2016
    AUSTRALIA
    13
    Quote Originally Posted by CNC Hacker View Post
    Yes I tried that but I will try again as per Philabuster's advice. Thanks
  7. #5
    Oct 2016
    AUSTRALIA
    13
    Quote Originally Posted by Philabuster View Post
    THanks man I tried similar but started at Z14 with a different stock value. I will try that.
