Mazatrol t plus
Likes Likes:  0
Results 1 to 9 of 9
Thread: Mazatrol t plus
    Sep 2019
    ALAND ISLANDS
    5
    Default Mazatrol t plus
    Hi. I would like to increase the distance that my u drill crosses in front of the work piece. Is there a parameter setting where I can change this? Appreciate ad help or advise. Thanks.
    Oct 2012
    Austria
    176
    14
    46
    On mazatrol T32, the parameter you need is I believe U5. I am not sure about T plus...
    Sep 2019
    ALAND ISLANDS
    5
    Thanks That’s great.
    Jan 2013
    Plainfield, Indiana, USA
    1,804
    1380
    958
    Easier to use the clearance height in the very first line of every mazatrol program. Parameter only sets the "R" plane if you choose to use it in a 'point' type sequence.
    Sep 2019
    ALAND ISLANDS
    5
    I’m not sure I’ve seen the clearance at the beginning of the program.
    Jul 2006
    Arizona
    4,713
    18688
    4558
    Quote Originally Posted by benrighton85 View Post
    Stock removal of workface on PNo0.
    Jan 2013
    1,804
    1380
    958
    Label is "Initial Z" iirc
    Sep 2019
    ALAND ISLANDS
    5
    Oh ok. I would like to change the distance for all process my understanding is that the work face would be removed in the first process?
    Sep 2019
    ALAND ISLANDS
    5
    Managed it using the u5 parameter. Very easy thanks for your help.
