Hi, I'm trying to make a 1.5" hole that's 3" deep and I'm using an 1" carbide than coated. I keep getting chatter while cutting cam anyone help me out with the speed and feed and depth of cut? I'm also helixing down.
.Hi, I'm trying to make a 1.5" hole that's 3" deep and I'm using an 1" carbide than coated. I keep getting chatter while cutting cam anyone help me out with the speed and feed and depth of cut? I'm also helixing down.
I'm cutting with a solid carbide square endmill coated with TICN it has 4 flutes 2 center cutting.3inch cut length 6inch overall length sticking out of holeder about 3.25. I have predrilled a 1inch hole. Cutting steel 4041 I think. Part is being held in a vice. Also have coolant.
Have a kurt visewas running at 800 rpm and 4.5ipm not sure the helix angle cam software figured that out, each rotation is .02 deep. Running on a fadal.
Please tell me your not hand writing code
What possible difference would it make if the code were hand written or generated by software?
Do the fat fingers make programs in operation worse somehow? Jockey
do you really think someone can help you with the details you've given?
Notice
