chevydyl
- Nov 23, 2014
- Sterling, Ak
hey all, im back with my retrofit upgrade. my m50 finally breathed its last breath, so i tossed in the m64b i had got awhile ago, in the past the 64 would not take my 50 plc file, so with nothing to lose now i hand entered the 2000 steps.... geesh. im going to paste an email i sent to Mitsubishi regarding this issue. it will not let me set work offsets. what i need is someones ALL1 file from a similar type machine, simple 3 axis vertical with tool changer. it takes my m50 ALL1 file but isnt right. Mitsubishi thinks that because i dont have an m64 file it reverted to base specs, like base model no options... they advised me to try and find someone that would allow me to try there file, they also where going to search their database for a file i can try, to at least get the control to a M control. right now its an M64B-D, D meaning drill. although it came from a VMC. @vancbiker may recall me posting of this in the past. and i know @NAST555 has an M64 control, this is kind of my last chance before i have to send the control in. i would like ro express that if an ALL1 file is shared with me i am fully responsible for its use on my machine, at this point covid has beat me down, loss of clients and then my machine going down. anyway help is greatly needed. heres the enail contents explaining the issue btw the machine is an Amera-Seiki DTM-40
ok ladder is hand loaded, still get the no spec for work offsets, in mdi if i call g54 or any of em i get an error no spec. (although the control boots with G54 active on the bottom......) also when i first turned the control on i went looking in the parameters (before installing files or initializing RAM) and wow, there is a ton of the bit select parametrs turned on, keep in mind this control has been formatted and initialized several times by me, with my 50 parameters loaded. its all cleared out now based on me loading my m50 3 parameters file. i also noticed that the Ethernet settings were populated, no ethernet card though. i have pictures of all this (thought maybe i would turn on them bit select parameters). i have also gotten the control to go to ready state, spindle runs, axis move about half an inch in the zr-rtn mode. there was an emg para alarm for the door interlocks, which i found in the book and set, then another that i found in the book and set and wallah, ready state. machine is still unusable at this point. when i loaded my ALL1 file using the 1060 64 S input it wont let me format the control right away, NOT ACCEPTABLE error, although on the option page it shows several option populated. so i power throw and then format, it seems like it removed several option codes when this was done....i think it went from 6 option in the first row to 4 options. Im desperately standing by, this covid crap has hurt me bad, materials were unable to make it up to Alaska for my main client.
just one page, but every bit select parameter was like this, except the plc data bit select page, all * but a couple which had numerical characters, not just 1 or 0, even showed a - sign.
