jbrowne
- Oct 2, 2012
- Pittsfield, ME
We are working with 1/8" to 1/4" aluminum stock on a Bridgeport with an original Prototrak doing basic 2D patterns. We have recently run into some major issues with endmills melting the workpiece and getting clogged with aluminum, stalling the servos/moving the workpiece. This is happening with both two and four flute endmills.....with coolant (emulsified oil) applied at a constant rate from a spray bottle.
The following occurred while using a 1/2" 2 flute endmill at 1115 rpm and 3ipm feedrate. I know this is a low feedrate, but we ended up there after backing off from 8ipm to 5ipm and down to 3ipm, still applying constant coolant from a spray bottle. This was the third "stall and melt" incident on this piece....just normal 6061 extruded stock with 1/8" wall. A 1/2" 2-flute bit should be tearing this thing up, but we kept having awful cutting results??
We have encountered the same problems on brand new US made TiN coated 17/64ths two flute mills to 1/2" uncoated mills....we keep melting the workpiece.
Are we feeding too slow and letting the bit linger in the hot zone on the workpiece? My reaction to these incidents has been to reduce feedrate from theoretical max (using 0.004" per tooth)...but maybe I should be increasing? We were working at 300sfpm and backed off to 250/200. We found a reduction in chatter/squealing, but no improvement in the melting problem.
Thanks for any advice!
