Method of positioning lathe turret for tool changes - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21
    Mar 2006
    PHILIPPINES
    2,599
    629
    960
    Its far more convenient changing the Tool Change position by specifying a Machine Coordinate System position with G53 than having to change the parameter setting for G30.
    Most of the time and in most situations I would agree with that. For me it all boils down to, Ok, I have 3 reference points at my disposal. My parts are generally the same size so if I "Set and forget" my alternative ref points and just make a visual marker on the machine it's just kind of handy. Sure, You can always call up a G53 with Neg values to really get up close and personal but over 3 or 4 feet a few inches of tool change clearance is plenty. Our Toolmex is 60" swing by 708" between centers and I have the ref markers set about every 15 feet and very seldom needed G53.
    I really wish Fanuc would incorporate Siemens M6.1 for tool changes. Just jog the turret up to your longest Z tool then same with X tool and press (Tool Change position set) and just use M6.1
  2. #22
    Jan 2014
    Washington
    4,858
    875
    2615
    Quote Originally Posted by g-coder05 View Post
    .......I really wish Fanuc would incorporate Siemens M6.1 for tool changes. Just jog the turret up to your longest Z tool then same with X tool and press (Tool Change position set) and just use M6.1
    A person could write a macro........
  3. #23
    Sep 2003
    riverside, ca, usa
    384
    31
    98
    And assign that macro to an M-code...
  4. #24
    Mar 2007
    Salem,Ohio
    678
    19
    327
    Maybe the lathe already has a macro for doing this. Ill check tomorrow. It does have a few programs/macros that start with program number 9000. I know 2 of them find the steady rest and tailstock so you can pin them and move them to new location.
  5. #25
    Mar 2006
    PHILIPPINES
    2,599
    629
    960
    Can a soft key be created on Fanuc controls to execute a macro without being in MDI or Run mode? Not being sarcastic, Really don't know about creating soft keys on Fanuc.
  6. #26
    Jan 2014
    Washington
    4,858
    875
    2615
    Softkey functions are implemented through the ladder or builder U/I so no reason/need to use a macro then. The function's instructions would hard coded into the ladder or U/I program. Not something an end user would have the tools to do.
