WrenchX1
- Jan 22, 2013
- New England USA
Hello,
I'm curremtly having issues with the realtime board on a 1998 cincinnati milicron arrow 1500. the machine will at random alarm out for "realtime timeout" and the Z axis will make a sudden drop (roughly .125") at what seems to be full rapid. It has been looked over by multiple local CNC tech's and none of them seem to have any answers as to how and who can fix this issue. MAG IAS, LLC was also contacted and tech support told us to set the jumpers on the RTCPU from 100MHz to 80MHz. this fixed the realtime issue but created more alarms, "once per pocket switch failure" and "tool drum1 not parked". I also have recently replaced the power supply as i was told it may be where the problem is coming from, but it hasn't changed the issue with the timeout. So far the problems still seem to point to the RTB, If anyone can tell me where i can have the RTB replaced/refurbished or get me pointed in the right direction on how to troubleshoot this issue it would be greatly appreciated.
