camaro_dan67
Cast Iron
- Dec 4, 2009
- N.E. Pa.
My machine is a Kiwa Excel center-4 with the Fanuc 3m-c control. Yesterday I had it up and running and I walked away from it for 3 minutes and when I came back the servos were off. I cant reset the servos. The servo drives all have green lights at the vcc/rdy led. There are no alarms. I tried cycling the limit switches for each axis. Through turning the control off and back on I was able to clear all programs and parameters with the delete and reset buttons because I found 2 parameters that were not what I originally entered. I also cannot enter the parameters back in the control by turning on the parameter enable switch. Any ideas? Dan
