Iffin I had a Radial we prolly wouldnt of gotten to have this chat,or all this fun,but as aside ,I have been lookin at Radials.
Dung,I can change colors here?never mind that will cause 24 more posts.(ha?)
So start at the bottom and Z up with the tool,I like that,I looked at the woodruff cutters,I will look again.
The indexables selection seem slim to nun for a 1 1/4-7,they seem to be too large in dia. to do inch and a quarter,I will check on Scienctifics,thanks.
One thing that troubles me pea size brain is ,for example the woodruff cutter idea,does a given dia. of cutter,NOT provide enough clearance to make a proper thread,I am for sum reason thinking as the cutter enters and exits the cut it wood deform the thread......?
Next marble rolling around in my head is the indexables? say the insert is .75 long,so you could cut aprox. .75Plus.1429 in 1 rev. around the bore?if you wanted to cutt 2.00 deep do you continue to travel with the Z.1429 pur lap?or do you go back to center Z up .75 and do it again? This may sound like gibberiss,please forgive,as for the last 40 years I have been too busy makin chips tp inprove my writing skills.
Too clear up sum notions,I touched my 1st N.C, mach. in 79 never left em after that.
Prolly forgotten more than I rember aboot em,never ran production,onecesys ,most parts I ever made the same was 8 supstrates for the "new Ranger" pickup dash. the men I worked for never bought me thread mills, I used taps 2.00 - 4 1/4 was real normal,handling holes,eh?
So what aboot it folks can you tech this old m.f. to thread mill?
Maybe I should buy a Radial,the wifey is just settling down from my last purchase?
REspectfully
Gw
