Milling 7/8-6 Double lead Acme Thread.
Results 1 to 18 of 18
    Jan 2022
    Florida
    6
    10
    Default Milling 7/8-6 Double lead Acme Thread.
    Hello,
    I am looking for some advice on milling an internal 7/8-6 double lead Acme thread. I am working in a 5axis C42 Hermle and using CAM Software. I purchased a single point 6tpi threadmill and can not get it to create a good thread form (seems to be back cutting). The threads I am getting are washed out (coming to a point rather than a flat), though my GO Gage fits it is so washed out that my NOGO Gage fits as well. I am programming two separate 3tpi tool-paths the second's starting angle is 180 degrees from the first. I milled the minor right on the number and the major is right on as well. I suspect I need a special theadmill but not really sure.
    Any advice is appreciated.
    Attached Thumbnails Attached Thumbnails washed-out-threads-test-thread-gage.jpg   washed-out-threads-test.jpg
    Jan 2019
    Missouri
    609
    190
    166
    Dont you need a 3tpi threadmill? Or a single row.
  3. Likes Dwolf55793 liked this post
    Nov 2002
    3,480
    2238
    1018
    Your threadmill is not relieved enough on the backside to cut a 3 tpi thread.
  5. Likes Dwolf55793 liked this post
  6. #4
    Jan 2022
    Florida
    6
    10
    I think I need a 3Tpi threadmill but acme tip width changes when you switch your tpi. So it would have a wider tip width, and I really can not find a 3tpi Acme threadmill. Not sure about the single row though wanted some confirmation before throwing money at it.
  7. #5
    Sep 2015
    Ohio
    2,059
    1302
    2214
    You’re going to need more clearance. Just hand grind some on your tool.
    I’d say leading edge, but maybe I’m not visualizing it right.
  8. Likes Dwolf55793, doug925 liked this post
  9. #6
    Sep 2002
    Riddells Creek,Victoria,Australia
    553
    143
    100
    There are some strange answers here. The point is that you can not cut a 2 start thread with a threadmill designed for single start threads, the helix angle is only half so naturally it will not cut properly.
  10. Likes Dwolf55793 liked this post
  11. #7
    May 2017
    Minnesota
    2,846
    4026
    2081
    You can't threadmill a high lead acme thread, period. The path of the tooth obliterates the flank angle. You can only threadmill when the pitch angle is less than the flank angle.
  12. Likes Dwolf55793, TeachMePlease liked this post
  13. #8
    Jun 2002
    CANADA
    British Columbia
    3,550
    3729
    Hi Dwolf55793:
    There are a couple of important things you need to be aware of:
    First; the threadmill is like a saw, and a multi tooth threadmill is like a gang saw.
    There is no helix...it is just a saw with 14 1/2 degree faces.
    Changing the relief angle does nothing...it's still just a saw.
    There is no "helix angle" on the threadmill...each tooth around the periphery of the mill spins on a common plane, unlike a tap.
    The thread form follows a helical path, so there is an angle relative to the axis of the thread at which the saw fits best.
    For external threads, if you tilt the saw into the plane of the helix, you can cut a threadform that is the same as the profile of the saw teeth unless the face angles of the teeth approach zero (square threads).
    Square threads don't work because the helix of the thread is not a plane, but the saw teeth spin in a plane, so they'll clip the corners on the entry and exit sides of the cut.
    Because the thread profile also follows a helical path (non planar) for internal threads, the saw will interfere with the threadform as one or more of three conditions appear:
    1) the saw diameter approaches the thread minor diameter.
    2) the flank angle of the thread profile is reduced.
    3) the helix angle (thread pitch) increases.
    Conventional threadmills can be made to work on 3 axis VMC's because the threadmill is substantially smaller than the minor diameter, the flank angle is 30 degrees so it clears the thread flanks more (for a 60 degree vee thread) and the pitch is reasonably shallow for single start threads.
    All of these things are working against you for your double start ACME thread.
    So you have to fake it and accept what you get:
    First, you have a 5 axis setup, so you can tilt the cutter into the helix angle and rotate the part around the tilted cutter.
    Second, you can choose a cutter that's as small a diameter as you can...this means it will clip the profile less at the entry and exit zones of the cut.
    Be aware, as soon as you tilt the cutter into the helix angle, you are restricted in how deep you can internal thread...if you go too deep, you'll bang the shank of the cutter into the opening of the hole.
    This gets worse (obviously) as the helix angle increases, so with a double start thread, you cannot thread very deep.
    That's why it's not working for you.
    Cheers
    Marcus
    On edit: mhajicek: you beat me to it...you're exactly correct, but you can mitigate it a bit using the bodge I described above.
    MC
  14. Likes mhajicek, LexD, Dwolf55793, doug925, wheels17 liked this post
  15. #9
    Feb 2005
    9,923
    17325
    12189
    You can't do it. It is physically impossible in a 3 axis machine.
    You could have saved yourself a whole lot of money and just bought a tiny
    little key cutter, and you would have gotten the EXACT same results.
    I looked into it years ago. I don't remember if it was a 1-4 or a 1-5. ......
    Just went and looked, 1-5..
    So I drew it up.. Using the commercially available "Thread mill" that said it could
    do it.. It CAN'T.
    Notice how the flat blows out the entire thread form.. No need for any angles
    on the tool. Its acting as basically a key cutter..
    Increase the pitch and decrease the diameter, and its just going to get WORSE, and
    you'll get a result, just like you got.
    Even on a 60 degree standard thread that is thread milled everyday, you aren't getting
    a perfect thread form.. It may fall in tolerance, but its not "perfect".. Functional,
    in tolerance, everybody is happy, but still not "perfect" on the thread form. Close,
    but not as good as turning.
    I also modeled this up doing an external thread. That may be possible with messing with
    the geometry of the cutter. Internal, impossible.
    There is a reason that mass produced acme nuts are so expensive.. Its because they are
    a huge giant F'n pain in the ass.
    Edit: I think its neat to see the actual end results.... of something that wasn't going to work anyways.
  16. #10
    May 2017
    Minnesota
    2,846
    4026
    2081
    There are two ways I know of to get the proper threadform. One is with a tap, the other is single point threading on a lathe or turning center.
  17. Likes Bobw, Dwolf55793 liked this post
  18. #11
    Jun 2002
    CANADA
    British Columbia
    3,550
    3729
    Hi mhajicek:
    There is a third way, and that is to turn an undersize male electrode and burn it in with an orbital path on a sinker EDM.
    Good for when it's long and skinny or hardened or you need the threadform right to the bottom of a blind hole.
    Expensive to do, but sometimes it's the only way
    Cheers
    Marcus
    www.implant-mechanix.com
    www.vancouverwireedm.com
  19. Likes Dwolf55793, Bobw, mhajicek, TeachMePlease liked this post
  20. #12
    Jul 2004
    Houston, TX USA
    32,832
    Helix angle is 8.5 degrees at pitch dia. - tool has to clear this - even on your clunky engine lathe
  21. Likes Dwolf55793 liked this post
  22. #13
    Jan 2022
    Florida
    6
    10
    Quote Originally Posted by implmex View Post
    Hi Dwolf55793:
    Cheers
    Marcus
    MC
    Thank you for your explanation. I kinda knew the problem but could not quite grasp what was happening. This is a one off piece, what would you say my best course of action would be? I of course could tilt (not full understanding how that helps yet though), My shop also has EDM sinker, and a cnc lathe. the part I am cutting is not round but we could probably make a fixture for the lathe.
  23. #14
    Jan 2022
    Florida
    6
    10
    Quote Originally Posted by Bobw View Post
    do it.. It CAN'T.
    Thank you the visual is incredibly helpful. I am running a 5 axis machine does that make it possible to cut this, and if not whats my best option, I can EDM or we have a cnc lathe as well. The part is not round so I would have to figure out a fixture for the lathe though.
  24. #15
    Jan 2022
    Florida
    6
    10
    Hi mhajicek:
    Cheers
    Marcus
    Thanks, we may do this I have to cut 2.2" deep threads so this may be my best option.
  25. #16
    Feb 2007
    Aberdeen, UK
    4,934
    1833
    2480
    Quote Originally Posted by Dwolf55793 View Post
    5 axis makes it possible, with the caveat that the length of the thread must be sufficiently short that the tool does not hit the shank when tilted to match the lead angle.
    I suspect that is not the case on your thread, and most likely the answer is no.
    Given that ACME threads are almost exclusively specified for motion transmission, the surface finish from edm might be unacceptable, which leaves two options; lathe, or U axis single pointing if your mill is capable of that.
  26. Likes yardbird, mhajicek liked this post
  27. #17
    Jan 2022
    Florida
    6
    10
    Quote Originally Posted by gregormarwick View Post
    Gotcha, that makes good since. I think we will probably end up making a fixture and turning it in there with our Okuma lathe. Seems the most straight forward and the correct way to go about it.
    Thanks again for the help!
  28. Likes mhajicek liked this post
  29. #18
    Jun 2002
    CANADA
    British Columbia
    3,550
    3729
    Hi again Dwolf 55793:
    I'm with gregormarwick on this.
    If you can single point thread it in the lathe, it will be the fastest easiest way and it will give the best outcome with the least pain.
    So I also encourage you to find a way to fixture it in the lathe and give 'er a go.
    Should work brilliantly.
    Cheers
    Marcus
