Hello All
First post be gentle.
I am in the process of setting up our company's first VMC cell, with a new Haas VF2-SS. So Cat40, 12k spindle. Only machining 316 stainless steel, with sizes around 1"x2"x4". Surface finish is probably the most important metric, then dimensional tolerance.
With a lot of input from this site, I will likely go with Maritool for ER collet systems. However for final finishing, I'd like to use milling chucks, which Maritool does not provide.
How do milling chucks compare between manufacturers? Are the techniks comparable to lyndexs?
Thank you
Thank you
