Milling Extra Sacrificial Stock
Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Dec 2013
    India
    224
    135
    22
    Default Milling Extra Sacrificial Stock
    Hi All,
    Need a little help.
    Attached is one of the strips which we are machining.
    OP1 includes Overall outer boundary machining, facing side one, drilling/boring these holes. So most work is done. Only remaining is removing extra material in OP 2. Highlighted in blue color.
    This is a job where sizes are many, individual qty is less to justify dedicated OP 2 fixture cost. All those go in a set.
    Again, making identical soft jaws won't be justifiable.
    Lengths vary from 4" and go all the way upto 10".
    Suggestions for OP 2 please ?
    Oct 2005
    22,780
    Quote Originally Posted by Vishrut View Post
    Hi All,
    Need a little help.
    It looks like you could just Blanchard grind the backside off.
    Sep 2017
    Wisconsin
    1,506
    403
    968
    Yuck.
    Use a straight edge for orientation and clamp in two places, mill accessible areas, then move the clamps and mill the remaining stock?
    That or leave extra material in three or four places that you can clamp onto and then just tab them off on OP2?
    Jun 2012
    Michigan
    6,272
    5867
    4017
    Another vote for Blanchard Grind.
    Or maybe vacuum table, mag table, etc..
  5. Likes Vishrut liked this post
    Dec 2013
    India
    224
    135
    22
    Quote Originally Posted by Rick Finsta View Post
    Yuck.
    Doing exactly right now. Takes time fiddling twice with clamps.
    Sent from my Redmi Note 7 Pro using Tapatalk
    Feb 2008
    MI, USA
    1,074
    75
    443
    you say they are different lengths, but are they the same radius/diameter?
    Because if they were the same radius, or maybe you only have a few different radii, then you could use the same jaws for the long one as the short one, if you're just facemilling the back off...
    Dec 2013
    India
    224
    135
    22
    Quote Originally Posted by Mtndew View Post
    Wondering if can take big cuts in mag table. Material is 1095 heat treated steel ~ 28-30 HRC. Stock to be removed is almost 3mm deep.
  9. #8
    Dec 2013
    India
    224
    135
    22
    Almost 3mm stock to be removed. Will take too long IMHO.
  10. #9
    Dec 2013
    India
    224
    135
    22
    Quote Originally Posted by dandrummerman21 View Post
    Can't. Multiple Radii starting from R125 all the way upto R200 mm. Each pc has different radii.
  11. #10
    Aug 2015
    Utah
    16
    38
    I was just shown this recently. https://www.techniksusa.com/product/...c-workholding/ it looked pretty neat.
  12. Likes Vishrut liked this post
  13. #11
    Nov 2014
    Florida
    6,380
    2551
    3158
    Have you ever run a blanchard? 3mm will take nothing, plus you can load up multiple parts at once.
    Blanchard Grinding at Kinetic - YouTube
  14. #12
    Dec 2013
    India
    224
    135
    22
    Yup. Ours is a mini version sort of Milling Extra Sacrificial Stock. Just 10HP motor.
  15. #13
    Oct 2005
    22,780
    No it won't.
    1. Your running the BG and the first OP at the same time.
    2. Your running multiple parts on the BG table at one time.
    3. The set-up time on the BG is almost nill, just squeegee off the table, load new parts.
    4. Those parts look like they will stick well to the magnet, put the load meter right up to "10".
  16. Likes Vishrut liked this post
  17. #14
    Sep 2018
    Michigan
    178
    33
    94
    Are the holes just clearance for screws, Location fairly open?
    Why not..
    1:finish thickness and put in holes
    2:Bolt to scrap plate using screw holes and profile mill.
    It will probably be easier to keep them flat this way, and you can allow the entire profile to spring before you do a finish pass. If you really had to you could even leave a bit of stock on the holes and finish mill them to get thee size/position as true as possible.
  18. Likes Vishrut, Slugo liked this post
  19. #15
    Sep 2017
    Wisconsin
    1,506
    403
    968
    That was my first thought as well but I couldn't come up with how to easily/quickly handle all the different parts with differing radii and hole patterns.
  20. #16
    Oct 2005
    22,780
    Quote Originally Posted by TheBigLebowski View Post
    Why not..
    If you've got a "Plate full of holes" what is to keep the operator from loading the next part (In the middle of a run) from picking the wrong holes, and trashing the tool & part ?
  21. #17
    Jun 2012
    Michigan
    6,272
    5867
    4017
    Nah, blanchard grinders remove that much stock all the time.
    Besides, it will be faster than milling them to thickness because you can toss a bunch of them onto the grinder at a time.
    I'd seriously look into that.
  22. #18
    Oct 2007
    SPAIN
    5,732
    1575
    860
    Hi All,
    Need a little help.
    Some times, whether you want to or not, a fixture is the only real way to do things.
    You could layout all parts overlaying eachother on the one fixture plate, and look to use miteebite (or okvise) type clamping.
    1x fixture for multiple variations (so the cost is amortised) shouldn't break the bank....
  23. Likes Tom Lg, doug925 liked this post
  24. #19
    Jun 2012
    Michigan
    14,351
    4889
    5193
    One might drill the holes on the mill and with a special faceplate turn that radius on the lathe, might make it full round and so two parts made in one setup.
    Q: 132.66 mm?
  25. #20
    Dec 2013
    India
    224
    135
    22
    Quote Originally Posted by michiganbuck View Post
    Q: 132.66 mm?
    132.66 mm is the outer radius of profile. Shown just to get an idea of the size.
