Milling out a broken tap - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 47 of 47
  1. #41
    Feb 2013
    Idaho
    765
    172
    881
    I always try to tig on a nut before I try anything else. I just lay an appropriate size hex nut on top of the tap, and tig down in the hole with a little SS filler rod. Let it cool down and the tap usually comes right out. I think the intense heat helps a bunch.
    I got really really good at it a long time ago. Weird, I don't recall the part or the reason, but I remember doing this way more often than is remotely reasonable. Then again, that was probably 25 years ago, before Bob Dole invented thread milling
  2. #42
    Sep 2006
    Middletown, PA
    494
    167
    83
    Just saved a part with a 5-40 stuck in it. (G84 depth too deep)
    Used a 3/32 EM in a G81 cycle at .5 IPM 3000 rpm .100 depth at a time until .350 dp. reached. Part saved, EM in the drawer for tap removal only.
  3. #43
    Nov 2013
    Idaho, USA
    Like others have said, you can bust 'em up with a punch and pick the pieces out. You risk damaging the minor diameter this way.
    I have had success plunging taps out with a carbide endmill. Something slightly smaller than the minor and with a corner radius. High speed, low feed. Smallest increment on pulse wheel.
    Quote Originally Posted by roysol View Post
    make dust.
    Clear the chips often with air.
    EDM is the least risky.
  4. #44
    Jan 2012
    mo
    22
    5
    Tig weld a nut to it. 5x faster and works a lot better than the endmill route. I haven't used an endmill in yrs.
  5. #45
    Feb 2004
    Napa, CA
    2,632
    45
    698
    Quote Originally Posted by caddyman707 View Post
    Depends on how deep its broken.
    Sometimes easier to tig a washer to the broken stud or tap as it is thinner, then tig a nut to that. But if its broken 1D deep or so, machining it out is the only choice.
  6. #46
    Aug 2015
    Illinois
    1,502
    1110
    649
    I have been tempted to try small diamond core bits to cut out the center of the tap. Here is a product I plan to experiment with.
    10pcs 3mm diamond coated hole saw drill bits set core marble glass granite drill bits Sale - Banggood.com
  7. #47
    Sep 2016
    Idaho
    77
    7
    22
    Thanks for the tips,
    M4 1/2 deep use 1/8 endmill
    7500 rpm 1ipm, .1 peck, air only.
    Sucker was glowing nice.
    Worked like a champ.
