I would like to machine a surface knurl on a flat part using an old Deckel with Sinumerik control. The control has a very small memory with no capacity to DNC so I am looking for examples of a macro one could use to create the repetitive pattern. I basically just want to make a diagonal cross hatch with a 90 deg spot drill, maybe 0.05" depth. So it would be like if you rolled out a diamond knurl you would turn in the lathe.
Any insights would be appreciated,
