I'm running Camworks programs on a Milltronics RH25 with a Centurion 6 Controller, and I'm running into a weird issue. In the middle of some operations, it's making a really long linear move out to the edge of the part and back again before continuing the toolpath, or if it's volumilling, it will sometimes make a full circle outside the feature and then continue as though nothing happened. I can't find these moves anywhere in the G code, and it doesn't show up when I simulate the program in Camworks. I've seen it happen with conversational programs as well. Also, sometimes it doesn't do it if I start the program at that tool rather than from the beginning. Has anyone encountered this before? Can anyone help?
Edit: Centurion 6 controller, not a Centurion 8. Ours is so dirty I can barely read the markings.
