Milltronics partner 1 centurion v
Likes Likes:  0
Results 1 to 4 of 4
    Nov 2020
    POLAND
    Default Milltronics partner 1 centurion v
    Hi, I have a problem with my milltronics mill.
    When I start up machine everything looks ok, system boot up fine. Since I own it when I was starting machine a alarm of 450 appears, but when I pressed RESET button alarm has gone and machine was working fine for homing, but yesterday when I pressed RESET the machine switched off and coundnt get it running. Any ideas what can be wrong? I can send video with this what happend when I tried to start it up.
    Thank you
    Dec 2016
    ALAND ISLANDS
    Had the same problem, it had a faulty limit switch on the x axis. Make sure your limit switches are in working order.
    Sent from my SM-T337V using Tapatalk
    Nov 2020
    POLAND
    I was checking it and they are good, do you got any other ideas? It's a nightmare, I dont know what else could be wrong..
    Jul 2002
    Phoenix, AZ USA
    1,756
    59
    230
    Maybe a long shot, but when I was bringing my machine up from the dead, I found a resistor that goes from the big blue capacitor to the chassis. If there is any short on the system, these resistors tend to blow, then the machine won't run. It's the white squarish block on the left.
