Mistcollectors
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Mistcollectors
    Jan 2007
    Iowa
    54
    85
    24
    Default Mistcollectors
    We are thinking about adding mist collectors to our cnc machines to control the smoke and vapor coming off our lathes and mills. We have a Royal filter mist collector on a couple of lathes that work ok. What do you guys think works the best with the least maintenance.
    Sep 2014
    Minnesota
    198
    81
    123
    We run the a Losma Darwin system on our lathes. Works well, low maintenance, but the filters are expensive and tend to have longer lead times. Really makes a difference for smoke too.
    Feb 2014
    Sunny South West Florida, USA
    3,098
    11139
    3501
    Royal Tri-Mist or Cool Blaster. Downside, they're expensive, and the filters have to be cleaned. Upside, the filters are reusable, and I have yet to see one break down, and I've seen them run for 3+ years, pretty much 24/7, 365.
  4. Likes RevetsP liked this post
    Feb 2013
    Auburn, WA
    696
    43
    826
    The Royal FilterMists are pretty low maintenance, they separate more mechanically and just use a simple filter for inlet air.
  6. Likes Space Wolf liked this post
  7. #5
    Apr 2015
    Minnesota
    Quote Originally Posted by jdowd View Post
    We have an air quality specialist in our facility and we have worked with Handte Mist Collectors in many applications across multiple processes. They are durable and work great. The filters can be cleaned for reuse. Most mist collectors have filters that are an investment but will last quite a while. I am available for any questions if you would like.
  8. #6
    Sep 2014
    Minnesota
    143
    52
    45
    We have a pretty big shop, tried almost all the brands of mist collector on both oil and water based machines. Absolent is now our only choice. Our maintenance guys love them. Filter cost isn't bad either. They're super quiet, and work very good at removing mist. Almost all our machines are high pressure (>1000 psi) so mist is something we must worry about.
    E
  9. #7
    Jul 2010
    South Africa, Cape Town
    418
    101
    140
    Slightly off topic, but still related and hopefully complementary to the OP's question.
    When using mist collectors, do they collect the mist or do they condense it and return it to the sump? if so, what is the recovery rate and how much coolant would you lose in a day? (maybe rephrase that to: do you lose a significant amount of coolant when using mist collectors? Would you lose more with or without?
    Are they mainly used to improve air quality, prevent coolant loss or protect the electronics from that sticky black residue you find in well used machines?
    Any other Pro's/ cons criteria that should be considered when choosing a mist collector system?
  10. #8
    Sep 2005
    il.
    6,669
    31
    1237
    Most do have a condensation return. Return is minimal. " I think" the coolant loss is mostly unchanged. But I have never really talked to the science team about it. It does make a real difference in air quality when the building is closed up.
  11. #9
    Dec 2007
    Southeastern US
    6,401
    845
    2808
    We use AirFlow Systems. They do an excellent job.
  12. #10
    May 2013
    Near Seattle, WA
    1,019
    258
    830
    Quote Originally Posted by Tonytn36 View Post
    Not sure if its the same for everyone, but this was somewhat comical. The Viglink system created a perfectly reasonable looking hyperlink out of 'AirFlow Systems'.. but rather than linking to mist collectors, it links to some dirt devil vacuum filters. Classic.
  13. #11
    Jul 2010
    418
    101
    140
    Quote Originally Posted by rlockwood View Post
    Yes, that ticked me off as well. I think it sucks that auto links are created without them being verified as accurate.
  14. #12
    Jan 2007
    Iowa
    54
    85
    24
    Thanks to all for the input.
  15. #13
    Oct 2019
    SWEDEN
    Check out the Swedish company 3nine. They manufacture different kinds of solutions with low maintenance and low required filter changes. The initial price is higher but the results are great!
  16. #14
    Jan 2003
    Canada
    11,324
    5554
    3462
    Aeroex are quite probably the best, and made in North America.
  17. #15
    Jan 2011
    Kansas
    738
    50
    58
    We are using Mist A Way. They seem to work well and are more economical than some.
  18. Likes Snipes44, Panza, repairguy923 liked this post
  19. #16
    Jun 2013
    Oregon
    1,559
    553
    930
    Royals are centrifugal. They do not work well if you create a LOT of mist/smoke. Filter cartridge types are more expensive, but handle large volumes well.
  20. #17
    Jan 2003
    Canada
    11,324
    5554
    3462
    The Aeroex system seems to be able to handle a fair bit of mist.
  21. #18
    Oct 2005
    16,614
    Quote Originally Posted by Ch_re View Post
    Spammer dredging up old post.
  22. #19
    Oct 2019
    Michigan
    10
    Quote Originally Posted by munruh View Post
    We're currently using the Mistaway MA700 & MA1200 on our machines. We've had them for around a year and they work great. Our PM tech cleans them out every 3 months, they're very easy to clean and the filters are very affordable. In my opinion, the units perform very well.
    You can even buy a their "Mist Manager", which is essentially an amp clamp you put on one of the spindle leads or coolant pump leads, sending power to the mist collector. This way your mist collector is only running when your spindle or coolant pump is running. I have ours on the spindle so it comes on when using accu-lube. They're also very easy to install so you won't have to pay any installation fees.
  23. #20
    Dec 2002
    Granville,NY,USA
    3,940
    337
    430
    Another vote for Mist away. I like it better than my Royal. It's way quieter and seems to do a better job of removing mist. Plus they are made an hour away from me.
