chevydyl
- Nov 23, 2014
- Sterling, Ak
Im upgrading my current control to a Mitsubishi M65A, MU021, using the DX451 Base I/O board. The machine, an Amera-Seiki DTM-40 originally had the M50. I have all the PLC and parameters saved from the M50. I have a couple questions, do I HAVE to have the HR412 memory cassette or is that just expansion/option upgrade. i know it says you can save user PLC and machining programs to this cassette, but also says that it is for maintenance ie parameter restoring and what not. My used control did not come with a cassette and most of the used M65 controls i see on ebay dont. It only states in the manuals that the M65S must have a cassette installed for the system to start. Mitsubishi told me that in order to unlock High Speed Machine mode and High Accuracy Control, additional work offsets P.1-P.48 etc i would need to order through my OEM and Mitsubishi would make a cassette for those options, you load it in the control and done, you can then take out the cassette. They also said that Memory Expansion cassette was also an Option. Please let me know, if i have to order a cassette i need to quick, thanks
