chevydyl
- Nov 23, 2014
- Sterling, Ak
I posted about this install before, I was able to get working accept for it won't rotate past 360deg, the axis is set to reference home, it is setup to be a rotary axis, without indexing. Im not sure what the parameters should be set for to make it rotate past 360. I ran a test program and everything worked great until it made it to 359deg and then the machine errors M01 OPERATIONAL ERROR, basically you've gone past the limit, however I have the limits set at the highest settings they can be I think 2013 is the overtravel parameter. Anyone with 4th and parameters willing to share or help me get this going, it's soooo close to being ready
