Help !!
I have a hartford vmc 850 with a mitsubishi Meldas 64 control and ive tried to change a parameter and screwed it up.
I was trying to switch the tool offset page type in the controller to show:
Height Hwear Radius Rwear
like this
The operators manual says switch parameter 1037 cmdtype from 1 to 2 and then go into parameter 1060 (setup) and reset.
I did this however i screwed up where it says, set base parameter (N) I pressed (Y) by mistake
now it shows an error S02 INIT PARAM ERR EMG EMERGENCY
How do i fix this ?
like this
How do i fix this ?
