Mitsubishi Meldas 500 - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21
    Jan 2021
    AUSTRALIA
    17
    7
    Quote Originally Posted by boslab View Post
    Your going to have to learn ladder program to go direct to the plc, 500 is similar to Siemens s5 from memory, ancient and unsupported, normally the plc connects to the HMI, think you better get the manual for the machine
    Mark
    Hi Mark, thanks; yes im looking for a manual for the controller found out its a melads 520am series
  2. #22
    Dec 2020
    Maryland
    204
    124
    42
    What is with all the hate here? I find some of these posts at the beginning of the thread to be rude and offensive. The man is asking for help and has to start somewhere. We were all newbies once. Put yourself in his shoes and try to at least act like adults and be courteous and understanding of his situation. It's just the right thing to do.
    Remember, you catch more flies with honey, not vinegar. If you can't be respectful and kind here, then there is no place for you here on this forum.
    My .02 cents
    Chris
  3. Likes Bogart999 9, machinist58, mutiny liked this post
  4. #23
    Jan 2014
    Washington
    5,571
    1006
    3130
    @machinist58
    There is a member on this forum, angelw, who is from Australia. One of, if not the, sharpest members here. Send him a Private Message and see if he would be willing to help. It would go much better in person or by phone rather than on the forum where the time lag between question and answer may be substantial.
    I'm pretty familiar with Meldas 50 controls and it is kind of similar to the 500 series. I can help with some questions, but it may be slow going back and forth. The machine builder has quite a lot of influence in how the control behaves. Parameter settings and the machine's ladder program are the most common factors in that.
    The Meldas control also allows the machine builder to install custom screens and routines to simplify operations. For example, my Mori with Meldas 50 uses a touchscreen and has custom screens and routines for setting tool offsets and workpiece offsets. Because those exist on my machine, I've never used the Meldas provided offset setting functions.
  5. #24
    Mar 2005
    Southwestern Ontario, Canada
    138
    9
    8
    Meldas controls are essentially the same as fanuc as far as programming. I have a 320, and an M80, and the programs are interchangeable, except for maybe something slightly different that each machine likes. Your standard g code will work, there is no need for anything out of the ordinary. Tutorials for fanuc programming will work as well, it will get you the basics to get started. Also as noted above, Mitsubishi tech support is good, you should be able to download all of the manuals and technical guides direct from them. Download a table of g codes and m codes, then start checking youtube videos to get an idea of where you need to go.
  6. #25
    Dec 2012
    OHIO
    255
    249
    217
    If you look up Edge precision or Peter Stanton on you tube you will find several videos were he is using a meldas 500 control on A Mitsubishi horizontal mill . He goes over several topics about the control that may be of interest to you.
  7. #26
    Jan 2021
    AUSTRALIA
    17
    7
    Hi Vancbiker,
    thank you, my controller is a 500 series
  8. #27
    Jan 2021
    AUSTRALIA
    17
    7
    Hi Chris, thank you i will have a look @ you tube
  9. #28
    Jan 2021
    AUSTRALIA
    17
    7
    Thank you Green Machine, i will check that out
  10. #29
    Jan 2021
    AUSTRALIA
    17
    7
    Hi cpifer3, thank you
  11. #30
    Apr 2013
    south australia
    125
    55
    25
    I think i have a 520 manual in pdf, pm me your email and i will see if i can send it to you.
  12. #31
    Jan 2021
    AUSTRALIA
    17
    7
    Default meldas
    Hi Snapatap
    thank you, i think i found electronic version on a site called E books.com,i will see how it goes.
