We've had this machine for a bunch of years,runs great for weeks and months . it runs production work mainly small stuff. it repeats and holds tenths all day everyday.
but these little bugs keep popping up at the wrong time and they make no sense.
Problem #1 is the z axis will shutter then kick off the Z drive with a over current alarm. sometimes once a year or month sometimes ever f'd day. just have to restart it and it runs.
this could be when its just sitting there or actually moving. it has a minds of its own. Ive cleaned and check brush's all conections and it still happens.
problem #2 spindle drive. if the power goes off or I have to shut it off to reset the x drive. I have to turn the main power on and off maybe up to 20 times just to get the spindle drive to come up with no led errors. led 123 on a fenric 5000 v2 type fsd-11ar-22
problem #3 spindle drive sometimes when you go to start spindle it comes up with a start failure when you turn the spindle on. this is alarm led 1 same drive. I was told that its either the speed voltage control reading negative or motor feed back, also said more then likely a loose connection on the 16 pic cable.
problem #4 spindle drive for live tooling.(separate drive from main spindle drive) sometimes get an error when turn rotating tools on. if I do I let it set for one hour and it starts up just fine and runs forever or untill I shut the machine off on the main power.
I been leaning toward loose wires due to the age but I haven't found any in the last 5+ years. you guys have any ideas on what to look for?
problem 1 2 and 4 shouldnt be tied together all different systems as near as I can tell as they really aren't connected to each other or relate to one another. but I'm not sure. could they be?
back in dec this did the same thing then ran since Jan problem free up until the last week.
Edit Forgot to add
problem 1 I looked at the following error on dig/prm 800 and 801 800(x) hold 1's and doesnt flicker. 801 (z) goes between -4 and -3 constantly. Tried to adjust offset pot and made no differnce. gain and tach pot no difference either
Edit Forgot to add
