Need some help I have a older Miyano LE22 lathe with a funuc OT control and am having trouble getting the tailstock to work . It will move foward and back but I can't find anything about programing or setting in the manuals other than M26 is foward and M27 is back to home . It will go back in MDI but when I command M27 the machine alarms out . Diagnostic 306.4 says its the foward switch .I can sort that out but the real question is how do you set it just command foward and when it hits the parts it stops or do you set a limit switch IDK .I've tried to set the b axis but that doesn't seem to work . Any help would be appreciated .I have had the machine for several yaers just never needed the tailstock . When I call the manufacterer They don't know the machine as it's old so Idea's .
Thanks ,
Pete
Thanks ,
Pete
