Hello,
I have a 1987 Miyano TSV-21 with an Fanuc 0M-A control. Installed a 15hp phase converter, looking for a latter diagram / Breaker on machine on/off switch terminals diagram. I'm not sure if i have the phase correct and if the 120volts is going to control. The machine Control comes on and machine handle axis works for x,y,z. I'm getting ATC area alarm when i home Z. I changed a proximity switch on ATC and checked all limits plus proximities and all are working. Spindle will not index or turn on. Machine seems to be in an interlock state. Side note. this machine has an air/oil separator for the air plumbed to a solenoid the spindle has air going to it for the toolchanger and draw bar but it seems like the machine isn't getting air and i'm not sure what the Mcode is to activate solenoid. I had a Fanuc tech look at the machine but he was stumped on getting the machine out of interlock. Any help would be appreciated. TIA.
