Monel 500 vs monel 400
Results 1 to 10 of 10
    Aug 2006
    greensboro,northcarolina
    2,622
    181
    705
    Default Monel 500 vs monel 400
    Any significant difference in machining this? We have cut a good amount of 400 , but never any 500. Mostly milling, but there is also some wire EDM work.
    Feb 2006
    Republic of Texas
    2,930
    Virtually no hands on experience with either but have a horror story from a customer. Set up to trepan K500 bars. First couple of batches went smoothly. Next batch ate tools screamed and squalled and just was a friggin' disaster. After much hair pulling, metallurgist determined that there was about one and a half percent more copper in the batch, making the material unmachinable even though the copper was within the acceptable range..
    Nov 2019
    CANADA
    Ontario
    643
    1015
    154
    only experience I have is that it is 100 monel more then the other, pretty much sums up my experience with it thusfar.
    Guest Guest
    I ran Monel the one and only time damn near 30 years ago, no idea what type. Pretty small tight tolerance Cnc Swiss parts, I still have nightmares. I was handcuffed to one machine for a couple weeks.
    May 2005
    Ohio
    433
    21
    125
    Monel 400 machines very similar, as far as speed/feed goes, as 300 series SS. Biggest difference is its greater tendency to tear on some machined surfaces.
    I have never run alloy 500, but plenty of 400. I would expect it to be more difficult based on the following from specialmetals.com
    MONEL® alloy K-500 (UNS N05500/ W.Nr. 2.4375) is
    a nickel-copper alloy which combines the excellent
    corrosion resistance of MONEL alloy 400 with the
    added advantages of greater strength and hardness. The
    increased properties are obtained by adding aluminum
    and titanium to the nickel-copper base, and by heating
    under controlled conditions so that submicroscopic
    particles of Ni3 (Ti, Al) are precipitated throughout the
    matrix.
  6. Likes Kingbob liked this post
    Dec 2009
    Louisiana
    536
    202
    317
    We run both occasionally but often enough that we keep a fair amount in our material inventory. Personally I liken monel 400 to a 304 or 316 in that it can be stringy and gummy, build up on inserts, chip control can be an issue. But good news for you if you have had success with 400 I, at least, find 500 easier to deal with. It cuts more like a hardened 17-4 in that it forms a reasonable chip, I'm not sure what inserts you are using but with what I use I have found good results with my sfm at or around 200. We turn, drill, tap and mill with no trouble. We make valve parts and probably 70% of what we run is 316 or 17-4 running on late model Mazaks so my views on machinability may be a bit skewed, lol.
    P.S.
    Take it slow, it's high nickel so heat build up is a concern, it is a predictable material at least, it's stable and not prone to tearing or random weirdness like on incoloy that suddenly work hardens. Drill with carbide, tap with new, sharp, high quality taps and plenty of oil. I love working with both as I find that 400 and 500 take a shine and polish and have a beautiful luster like no other material I work with.
  8. Likes woodchuckNJ liked this post
  9. #7
    Aug 2006
    2,622
    181
    705
    Thanks, from what I am hearing, it shouldn't be a problem. I'm shocked at the cost of a 5" diameter by 52" piece. Couldn't find any 3 1/2 square so I guess we will have to mill it square. Anyone know a source for 3 1/2 square?
    Sent from my moto z3 using Tapatalk
  10. #8
    Jan 2019
    Arizona
    1,292
    112
    522
    RJT
    dont sweat Monel it cuts like butter just slow, if your doing alot of milling then run a rougher and finisher tool make sure the tools stay sharp. if you can run oil do it cause your tool life will increase by over 150% easy.
    we mainly did small lathe parts and hundreds of thousands of them for a customer years ago Actually was my 1st customer in 1993 , long skinny parts with small holes drilled through usually around 1/8-.250 dia with .050 dia through hole and a .090 counter bore and up to 3" long. on occasion we did plates thickest I think we done was around 3/4".
    we ran the lathes on barfeed (non swiss at the time) matter of fact all omniturns for 10+ years. the mill we used was a fadal and acrolocs. again keep the tools sharp. if you can get away with it use a small rad on the rougher it will help save the finisher. dont over feed it either.
  11. #9
    Jul 2006
    Hillsboro, New Hampshire
    13,624
    2995
    9122
    I suspect that without needing enough to have a mill run of the 3.5" square, you'll have to cut from round bar. Just be careful and don't screw the part.
    An open die forging would likely be too expensive to be worth the fuss.
  12. #10
    Jul 2009
    Louisiana
    I just came across this thread looking for some tips on Monel 500 and your post made me lol.
