13engines
Stainless
- Jun 30, 2015
- Saint Paul, MN
2000 Mori Seiki SL-200SMC w/Fanuc 18i-TA/Mori MSC501
Lately I've been running a job with a fully loaded turret that keeps hanging up after the parting tool in No 8 slot. Not sure it matters, but this tool is thru coolant and has a very restricted coolant outlet. The turret works fine for all other tools. I've also held the program until residual pressure drops from the tool without it making any difference.
This is a servo driven turret with a hydraulic system that I'm pretty sure is operating or driving in and out a locking and/or position setting pin. The typical sound is clunk... spin to new tool... clunk. Especially noticeable when manually indexing one tool at a time. The clunks are definitely the hydraulics part of it all, as I can watch and feel the spool valve operating in back by the pump in unison with the sound.
During automatic operation I get the first clunk, then it hangs without any rotation. If I'm recalling correctly, on the screen in the buffer area are the MTN (Maintain?) and FIN (Finish) signals displayed. So obviously it's waiting for a finish signal. But here's the thing. To get out of the problem I go into Jog or Rapid Mode, which is needed for manual turret movement, and do a simple two button push that would normally advance the turret one space in either direction depending on which two of the three buttons are pushed simultaneously. What it does is it gives me the second clunk but no turret indexing. After that everything is back to normal until the parting tool in the program comes around again.
I can operate the manual turret controls in any fashion and it never misfires. I also created a looping program which ran in auto mode that indexed the turret two slots every three seconds. It just went on and on without a single problem. I re-wrote it to advance in the opposite direction and no difference.
Here is the code at the time of failure. Nothing here that should matter. It's the end of the parting tool and initiation of the next tool. I even got rid of the M00 to see if that mattered and no change. I also changed the next tool number to something else and that didn't matter either. This transition or tool change coding is typical for all tools so nothing new here.
G99G1X1.866F0.0035
G4P25
U0.02F0.01
M5
M9
G53X-2.
G53Z-2.
T0200(FACING)
M00(KNOCK OFF PART)
G20G40G54G80G97G98
G0Z-1.T0202
Other tidbits of potentially helpful or useless info.
The turret is bi-directional in auto mode but not in manual, except for when you do the two button simultaneous one station index routine.
I get some coolant leaking out of the let's call it crack where the rotating and stationary parts of the turret meet. Is this normal, or a sign that some internal seals need replacing? Should this be dry as a bone?
Anyway... this is a freak thing and has me stumped.
I do have all the books but no ladder manual.
My wild guess? Which doesn't completely explain the difference between auto and manual mode. I got a feeling it's something purely mechanical holding up the lock pin from full movement, and has to do with the weight distribution of the fully loaded 12 tool turret. I've got 3 each of dual Z and single X axis live tools loaded, and a couple heavy dual turning tool blocks. Nothing strikes me as lopsided looking at the tool distribution, but you never know.
Thanks for listening.
Dave
G99G1X1.866F0.0035
G4P25
U0.02F0.01
M5
M9
G53X-2.
G53Z-2.
T0200(FACING)
M00(KNOCK OFF PART)
G20G40G54G80G97G98
G0Z-1.T0202
Dave
