Mori NH4000 touch probe problem
Likes Likes:  0
Results 1 to 4 of 4
    Feb 2020
    Oregon
    Default Mori NH4000 touch probe problem
    so new job has a mori Seiki with an MXS-501 controller and i have never used 1 and the guy that was supposed to train me quit. i have the basics of running a fanuc controller but the tool touch off program is getting stuck in a loop and is set for no edits. just wondering if anyone can help
    O9007(TOOL SETTING=400)
    #3003=1;
    #33=#4003;
    M9;
    G0 091 G28 Z0;
    G0 G90 G53 X-12. Y-22.08;
    G#33;
    #3003=0;
    M99;
    this is the whole program
    Thanks in advance
    Jan 2014
    Washington
    4,855
    874
    2613
    Comments in red.....
    Quote Originally Posted by timedilation View Post
    #3003=1; (DISABLES SINGLE BLOCK SWITCH)
    #33=#4003; (MOVES VALUE OF CURRENT GROUP 3 G-CODE (90 OR 91) TO VARIABLE 33)
    M9; (TURNS OFF COOLANT)
    G0 091 G28 Z0; (MOVE Z TO MACHINE ZERO)
    G0 G90 G53 X-12. Y-22.08; (MOVES X AND Y TO POSITIONS IN MACHINE COORDINATE SYSTEM)
    G#33; (RESTORES GROUP 3 G-CODE TO PRIOR STATE)
    #3003=0; (ENABLES SINGLE BLOCK SWITCH)
    M99;
    There must be more to the tool measure function than this one program. Probably other 9000 series programs. This appears to just be a way to position the tool over the setter and another program would actually cause the Z motion to touch the setter with the tool.
    Oct 2007
    Norway
    93
    5
    This program is basically just homing the Z-axis and positioning the machine in X and Y. (assuming the "091" on line number 4 is a typo for "G91")
    M99 on the last line will jump back to the program that called the macro, but if you run the program directly it will jump to the top, which I assume is what is happening here.
    Call the program from MDI with M98 P9007 and it will run once.
    Feb 2020
    Oregon
    evidently i just needed G324. touched off the tool no problem
