Mori Seiki MV JR MX2 Parameters reset
Likes Likes:  0
Results 1 to 2 of 2
    Mar 2019
    Maryland
    Default Mori Seiki MV JR MX2 Parameters reset
    Greetings
    I just experienced a power blip ( electrical) that happened during a tool offset measurement. I have had power blips before and it scrambled my parameters.
    I have a home shop and make my 3 phase power with a TEMCO converter.
    This time I went through reloading all the parameters again only to find that it is stuck in a #35 tool change not complete. That would not normally be a problem except this time I can not home the axis. The X moves but does not home. The Y and Z won't move at all. I manually returned the down pot to it's home position and that cleared my tool # 35 problem. My 7000 parameters all had a 2 4 2 4 2 4... setting. I manually reloaded /cleared all of them.
    And after all that on power up I got a CPU error. Then next time I did not get that however the Y and Z still won't move. I have checked Relays,connectors,fuses, parameters again only to find that the #7000's have 2 4 2 4 2
    Example
    #7000 2
    7001 4
    7002 2
    all through the #7000 series.
    What I would like to do is wipe the parameters and start from scratch.
    I have a set of spare boards with minor problems but they will work to power it up.
    In the cabinet there is a rotary switch for writing parameters and I believe some where in the past I was told to set the switch to 9 and erase the whole set.
    Thanks for any help.
    Apr 2019
    Florida
    I too have a Home shop with a 86 Mori MV junior and I ran into the same issue. How did you go about returning the pot back, and reset the machine? I am new and trying to figure it out as I go. Any insight is Great!
    Thank you!
    Bryan
