Hi i am from the UK we have a 1988 mori SL25 with fanuc 10 control. When it is switched on it starts to boot up and gets as far as (load PC parameters :end) then the screen goes blank the lights are still all lit up on the control but there is the red error light lit up but you cant see the problem as there is nothing displayed on the screen. There are no fanuc fault codes showing on the boards and I have had the screen and 24v power supply tested and they are all ok. I've had an x fanuc engineer look at it that started out on these old controls but he said hes never seen anything like it. I don't really want to call fanuc out as for how much they charge to get it running I could probably buy one in working order
