chad883
Cast Iron
- Jan 12, 2012
- indiana, usa
I have been getting a spindle alarm AL-26 on my Mori SL-25Y. MF6 control which is a Fanuc 16 from what I can tell. I stared checking the wires from the intergral spindle and they all checked out fine. Started checking the last wire from the pre-amp to the spindle amp and had to move my trouble light, When I hung it on the Z way cover I noticed there was a tiny spark between the hook on the light and the cover. I started checking and found 13 VAC to all surfaces. The enclosure, the frame, anything I checked that should not have voltage did.
My question is, could this cause my alarm, and any pointers on where to look for a shorted wire?
Thanks in advance
Thanks in advance
