Moriseiki mvjr 333 fuse and 332 fuse help
Crapo
Sep 4, 2019
Power up my mori for the first time then every thing went blank.
If I hold down a magnetic switch I get the CRT screen to power up and it has some error codes:
363: Pg error (z)
362: pg error (y)
361: pg error (x)
333 fuse (z)
332 fuse (y)
Use msg
30*airpressure down
46* spindle alarm
47* sp.stop signal off
Lsk alarm
Dose anyone have anything to help me
Those alarms are from a Yasnac control. Dan's suggestions are a great starting point. Kind of feels like a power supply issue. Need a little better back story too.
Ugg finally got back to it a little more info on my mvjr. Never seen machine run bought from a shop i worked at they used occasionally over 10 years then put in storage for 10 Years. Yes has yasnac control, every obvious fuse is good i can't see any reason why it wont power up beyond holding down magnetic switch. Machine is written 208 v i assume it is 100v per leg and wild leg is 208 volts
If you've never run it before and it's having power problem, perhaps you need to swap two legs.
If it hasn't run in ten years you could have a dead parameters battery? If so it might not be worth messing with.
