Bob La Londe
- Sep 26, 2012
- Yuma
99% of my paying work is cutting aluminum (flood), but I still sometimes need to make a steel part. I am still very much a hack/hobbiest in skill level when making steel parts.
Yesterday I was cutting some 4140HT with 1/2 AlTiN and 1/4 (coating unknown, but probably AlTin) end mills. I was getting lots of blue chips, but the 1/2 would certainly start to give a dull glow that under dim shop lights was barely visible. I gerry rigged up an air blast that came off my CNC wood router and bungee corded it to the side of my liquid coolant system. The parts looked better (although they weren't bad before) and the mills no longer started to glow. The stock didn't seem to be getting excessively hot in either case. Now I am sure my cut should have been optimized somehow to reduce heating up of the mill (the edges did not break down), but I don't make enough steel parts to justify spending a lot of time "just getting the feel for it." I plug numbers into an SF calculator and run it. Then I make a few adjustments to speed or feed over ride if necessary so I get good looking chips and eliminate or reduce anything else bad I notice.
My plan is to setup a semi permanent air blast on a sliding mount like my liquid coolant system. I figure for the amount of steel parts I make (mostly shop tools) the air blast is the easiest way to get the jobs done.
Now all of that is just background. I don't really need affirmation of it. Its what I did. It worked.
My question is: Is there any particular air nozzle design that might make more efficient use of the air? Maybe a laminar flow design that gives a consistent cone of air without a lot of waste air swirling away before it hits the tool? I have three machines with air seal spindle and two others that use some air. I'd like to not worry about exceeding the capacity of my refrigeration dryer or having the air compressor cycle to often when I am using the air blast. The better answer of course is to get a bigger compressor and a bigger air dryer in the shop and just don't worry about it. The real answer is I can't afford to throw money at every problem. LOL.
Regardless of whether or not I can find a more efficient nozzle design, I also plan to build a ball mount with nozzle slide so I can quickly and easily point the air nozzle directly at the cut at the right distance to encircle the mill with the blast and clear the chips.
I'm not interested in a vortex tube. They use WAY to much air for my shop.
