My new Brother Speedio toolsetter offset mount
Results 1 to 6 of 6
    Sep 2007
    Washington
    5,253
    200
    1588
    Default My new Brother Speedio toolsetter offset mount
    Hi guys,
    The spirited discussion around MiamiCNC's machine selection motivated me to finally make an offset toolsetter mount. This is what I came up with:
    It's steel, so it will be super-duper accurate . I happened to have a piece of 3/4" wall steel angle on hand that I used.
    Couple things that I learned while making this:
    1. When mounted at the very corner of the table, you don't have any good options for skim cutting in-situ. A big facemill can reach in X and Y, but not in Z unless you have some big extended-length facemill. Endmills can reach in Z, but not in X and Y.
    2. Yes, parallelism of the mounting surface to the table is very important. After a couple tweaks, I got it close enough so that the error between big (5/8") and little (1/8") tools is ~.0001".
    Regards.
    Mike
    Dec 2013
    707
    230
    399
    Steel? It has to be Inconel! Just kidding... Aircraft grade billet aluminum works fine too. Nice job. I am sure it will serve you well.
    Feb 2015
    Missouri
    65
    16
    What toolsetter is that?
    Apr 2019
    Arkansas
    882
    288
    327
    its ok...should have sandblasted the mill scale off and engraved your logo in it
    Sep 2007
    Washington
    5,253
    200
    1588
    Quote Originally Posted by biglord4ever View Post
    Blum Z Nano
    Apr 2013
    205
    104
    Quote Originally Posted by Finegrain View Post
    Hi guys,
    Regards.
    Mike
    I thought about facing mine after mounted, but ended up using the supplied conical washer and dti to get it flat.
