So I have an XCarve, one of those hobby-class CNC routers based on a DeWalt trim router spindle.
I have started doing some light aluminum work, mostly cutting bolt holes and component cutouts into thin plate (3/16" - ish)
I have been using a carbide, coated, 3-flute flat end mill for this work. At 19,000 RPM, 30 in/sec, .020 DOC, no coolant this has worked well for adaptive clearing operations. I spiral-ramp the cutter into the work, and off it goes. The shallow DOC means it takes a little while, but the ability to precisely locate holes in X/Y and cut weird component fitting shapes makes it totally worthwhile.
Yesterday though I tried a parting operation where I attempted to cut the plate to size once all the pockets were cut. The program was a straight profile starting at one end of the plate and running straight down the X axis to the other end. Cut, retract, return, cut.
At .020 DOC, 30 in/sec the cutter made it in about 1/4" then snapped.
Ok... so set DOC to .010 in (almost set it to 0.10 in but caught the mistake on the visualizer before I ran it). This ran fine until the last pass. I have the cutter extend through the work 0.003 in to make sure I fully cut through the part, this made it in about 2" (on a 7" total cut length) and *snap*.
Given that the adaptive clearing operations ran fine, there must be something different about slot cutting that places more load on the bits.
So then - what is your advice to better run these sorts of operation? Slow down, less DOC, thicker bit?
