In some haste I picked up a very low hours Super NTMX from a French aerospace firm. You might call it a a barn find!
It is a late 2010 build, installed 2011 with 19” NT-IPS software.
The machine arrived and was levelled.
At first power on, the cabinet fans screamed into a very pleasing sound. After boot it took a little digging to find the FANUC English language settings but I figured it out in the end. I had the machine moving about fine and tested all axes and turret etc. Later in the afternoon I shut down completely and rebooted the machine. Nothing out the ordinary. I switched off for the day and went home.
Today, I cannot get the machine to fire up at all! The electrical cabinet fans do not start when rotating the main isolator yet there is power in and out at the external transformer.
Is there a simple sequence of reset events needed? All doors and cabinets are closed.
I do believe it is probably something simple like a tripped contactor or something.
Scanning through the schematics it looks like the 24V system does not appear to get its "enable" signal by the ... something ?
Any help or ideas would be greatly appreciated!
David.
David.
