I have an issue at lines N495 & N1510 when I run it in my okuma simulator it gives me a
"2553-02 ALARM-B BRANCH(IF,GOTO) No WHILE,IF-THEN,GOTO function" I don't see why it would'nt work and I'm scratching my head. Can anyone please help me with this I'm stepping in new territory at the moment.
Code:
$CB162012.MIN%
O1000
(MAT. CDA932 1=1/PULL 1=30/BAR)
( AM 2/6/14 MODIFIED FOR NEW BARFEEDER)
(G13 T0101 1/32 RADIUS 80 DIAMOND ROUGH O.D.)
( T0303 1/64 RADIUS 35 DIAMOND FINISH O.D.)
( T0808 .125 WIDE KENAMETAL CUT-OFF)
(G14 T0505 1/64 RADIUS .7500 DIA. CARBIDE BAR FINISH BORE)
( T0707 BAR STOPPER)
(PULL BAR 1.80 FROM CHUCK FOR SETUP)
G13
AA50=0303
AA51=0404
AA52=0505
AA98=AA50
TCT1 = 1
G14
AA60=0303
AA61=0404
AA62=0505
AA99=AA60
TCT1 = 1
G13
VCHKL=1.150
VCHKD=.1 (CHUCK BARRIER)
VCHKZ=-2.90 (Z-1.750)
VCHKX=.1 (ACTUAL POSITION CHECK)
G13
NSTRT
G14
NSTRT
G13
M25
G50 S5000
DIA1 = 1.25 (O.D. FINISH SIZE)
DIA5 = 1.00 (ROUGH BORE SIZE)
ZZ01 = -1.50 (FINISH LENGTH)
N10 V30 = 1
N15 COU1 = V30
N20 G00 X10.0 Z1.0 T0101 M09 M42 M05 P-05
N25 M01 P10 (O.D. HOLD)
G14
M25
DIA3 = 1.00 (I.D. FINISH SIZE)
ZZ03 = -1.50 (FINISH LENGTH)
N30 V30 = 1
N35 COU1 = V30
N40 G00 X10.0 Z15.0 T0707 M09 M42 M05 P-05
N45 X0.
N50 Z15.
N55 (BARFEED)
N60 IF [COU1 EQ 1] GOTO N70
N65 IF [COU1 GT 1] GOTO N115
N70 (LOAD NEW BAR)
N75 G04 F0.3 (DWELL .5 SEC)
N80 M84 (OPEN CHUCK)
N85 M104 (NEW BAR START)
N90 G04 F20.0 (PUSH OLD SLUG OUT + LOAD BAR)
N95 G00 Z.05 (RAPID TO .05 CEANUP)
N100 M103 (PUSH NEW BAR IN)
N105 G04 F7.0 (DWELL 7 SEC.)
N110 M83 (CHUCK CLOSE)
GOTO N155
N115 (BAR PUSH)
N120 M84 (OPEN CHUCK)
N125 G0 Z.03 (RAPID TO .03)
N130 M103 (BARFEED COUNTER)
N135 G04 F3.0 (DWELL 3 SEC.)
N140 M83 (CHUCK CLOSE)
N145 G04 F0.3 (DWELL .5 SEC)
N155 X10.0 Z4.0
N160 M01 P10
N200 G13
N205 X10.0 Z1.0 S4000 T0101 M08 M42 M03 P15
N215 X=DIA1 + .200 Z.01
N220 G01 X=DIA5 - .200 F.012 (ROUGH FACE)
N225 G00 X5.0 Z.1
N235 G00 X10.0 Z1.0
N240 X10.0 Z1.0 T=AA98 P17
N245 AA02 = V1 (V1 TAPER BANK)
N250 DIA2 = DIA1 + AA02
N255 X=DIA1 + .075 Z0.
N260 G01 X=DIA5 - .050 F.0055 (FINISH FACE)
N265 G00 X=DIA1 - .0483 Z.030 P30
N270 G01 Z0. P35
N275 X=DIA1 Z-.0242
N280 X=DIA2 Z=ZZ01 - .0071 (FINISH O.D.)
N285 X=DIA2 -.060 Z=ZZ01 - .0371
N286 X=DIA1 + .005
N287 Z=ZZ01 - .175
N290 G00 X=DIA1 + .200
N295 X10.0 Z1.0
N300 M01 P40
N325 G14
N330 G00 X10.0 Z4.0 S4000 T=AA99 M08 M42 M03 P15
N335 AA03 = V2 (V2 TAPER BANK)
N340 DIA4 = DIA3 + AA03
N345 X=DIA3 + .0483 Z3.0 P17
N365 Z.030 P30
N370 G01 Z0. F.0055 P35
N375 X=DIA3 Z-.0242
N380 X=DIA4 Z=ZZ03 - .0034 (FINISH BORE)
N385 X=DIA4 + .040 Z= ZZ03 - .0116
N390 X= DIA3 - .010
N395 Z=ZZ03 - .150 (BORE FOR CUT-OFF)
N395 G00 X=DIA3 - .050 Z1.0
N400 X10.0 Z10.0
N405 M01 P40
N425 G13
N430 G00 G97 X10.0 Z1.0 S1500 T0808 M08 M42 M03 P45
N435 X4.0 Z=ZZ01 - .125 M77 (CATCHER UP)
N440 X=DIA1 + .075
N445 G01 X=DIA5 - .100 F.004 (CUT-OFF)
N450 G00 X4.0
N455 M76 (CATCHER BACK)
N485 G00 X10.0 Z2.0 P72
N510 TCT1 = TCT1 + 1 (COUNTER FOR TOOL WEAR)
N495 IF [TCT1 GT 5] THEN [AA98 EQ 0404] (PARTS 5-10 WILL USE T0404)
N500 IF [TCT1 GT 10] THEN [AA98 EQ 0505] (PARTS 10-15 WILL USE T0505)
N505 COU1 = COU1 + 1 (COUNTER FOR BARFEED)
N515 IF [TCT1 LT 15] GOTO N530
N520 IF [TCT1 GT 15] GOTO N550
N530 IF [COU1 LT 31] GOTO N20
N535 IF [COU1 GT 31] GOTO N540
N540 V30=0
/N545 GOTO NSTRT
N550 M24 P75
N475 G14
N480 G00 G97 X10.0 Z12.0 S1500 T0707 M08 M42 M03 P45
N1500 G00 X10. Z15. P72
N1505 TCT1 = TCT1 + 1 (COUNTER FOR TOOL WEAR)
N1510 IF [TCT1 GT 5] THEN [AA99 EQ 0404] (PARTS 5-10 WILL USE T0404)
N1515 IF [TCT1 GT 10] THEN [AA99 EQ 0505] (PARTS 10-15 WILL USE T0505)
N1520 COU1 = COU1 + 1 (COUNTER FOR BARFEED)
N1530 IF [TCT1 LT 15] GOTO N1545
N1535 IF [TCT1 GT 15] GOTO N1565
N1545 IF [COU1 LT 31] GOTO N40
N1550 IF [COU1 GT 31] GOTO N1555
N1555 V30=0
/N1560 GOTO NSTRT
N1565 M24 P75
N1570 M02
