Need Advice for Turning Hardened Interrupted cut (60HRC)
Page 1 of 2 12 LastLast
Results 1 to 20 of 38
    Dec 2019
    VIET NAM
    5
    15
    Smile Need Advice for Turning Hardened Interrupted cut (60HRC)
    Hi everyone, i need some advice from u guys about the Hardened interrupted cut.
    We have a problem when we turning and facing the product which has 8 holes on the face, the hardness is about 60HRC. We are using the ceramic insert with data cutting: Vc= 80-120, ap= 0.25 for facing and turning, fr=0.08.
    Because of the small tolerance (5-10 mirco) we use coolant when turning (which is not good for hardness turning). capture.jpg
    The inserts do ok when they do the continuous cutting, but break when they meet the holes (1-2 passes break)
    Do you have any idea about that?
    BTW does the data cutting is ok?
    Sorry for my bad English...
    Thank guys!
    Feb 2005
    9,084
    14136
    10797
    Ceramics are almost the polar opposite of carbide.
    When you have an issue, do the opposite thing you would do with
    carbide.
    You need more surface speed through the interruption.
  3. Likes Matt_Maguire, thanh tam liked this post
    Jan 2006
    New York
    1,612
    697
    789
    CBN is your friend!
    Sent from my SM-G930V using Tapatalk
  5. Likes Philabuster, Mtndew, Jashley73 liked this post
  6. #4
    Nov 2014
    Florida
    4,076
    1614
    1897
    My limited experience with ceramic inserts is no coolant and no interrupted cuts, which you are doing both... Have you tried "roughing" and finishing with carbide inserts with a 'good' coating, something designed for hard turning? Couldn't tell by pic, but also maybe you could grind the face with the holes, then just turn the OD? That would save alot of problems and frustration IMO, if you can do it that way...
  7. Likes thanh tam, Dumpster_diving liked this post
  8. #5
    Oct 2011
    West-Central Illinois, USA
    1,281
    2049
    583
    Surface speed is way too low! As mentioned above ceramic recipes go the opposite direction from HSS and carbide. I’ll get to the interrupted cut later → First, how it works;
    Pure ceramic needs enough heat in front of the shear point to make the material plastic (wisker ceramics = “ceramic + solid carbides mixed” works much the same it’s just tougher). The chip will be a very bright red to orange ribbon when it’s running right. If you see sparks behind & underneath the chip that’s the wear land slowly eroding (still leaving a good edge) & it will run a very long time before failure.
    Your Vc (speed) looks like my data from Metcut in 1966… Ceramics for machining were just getting started. By the 1970’s we had whisker ceramics that were doing well with 60Rc steels running in the 200M/m range, DRY. That put on quite a show...
    With interrupted cuts some estimated the percentage of the void & increased the speed recipe by that percentage amount (easy for the machinist). Industrial engineers writing part routing, ops & programs would actually calculate the voids, reduce the circumference by that amount and set speed for that (reduced) diameter. They both end up close.
    Good luck,
    Matt
  9. Likes Bobw, thanh tam, cnctoolcat, Jashley73 liked this post
  10. #6
    Dec 2019
    South Carolina
    8
    Use a low content solid CBN. The only company that offered the low content in solid used to be Ceramtec out of Germany. Not sure if anyone else had done the same. It is specifically designed for interrupted cuts.
  11. Likes thanh tam liked this post
  12. #7
    Apr 2018
    UNITED KINGDOM
    2,947
    1366
    This is why they make grinders ....
  13. Likes yardbird liked this post
  14. #8
    Jun 2012
    Michigan
    4,830
    4425
    2921
    Quote Originally Posted by EmanuelGoldstein View Post
    In a perfect world yes, but in the real world sometimes you have to finish a part on the lathe.
  15. Likes twjames79, Bobw liked this post
  16. #9
    Jan 2014
    Temecula, Ca
    2,980
    1316
    3840
    grinding of heat treated steel is forbidden in the aerospace world.
    I second the CBN.
  17. Likes litlerob1 liked this post
  18. #10
    Jan 2019
    Arizona
    755
    66
    251
    Mike
    interrupted cuts work just fine with ceramics, but you have to go fast SFM. basically your faking the insert to think its a solid cut.
    with ceramics you can achieve enough rpms to fake it out. with carbide you cant as it will burn up the tool.
  19. Likes thanh tam, litlerob1 liked this post
  20. #11
    Jan 2005
    CANADA
    Saskatchewan
    10,236
    1395
    3688
    CBN might be the answer, although I am not convinced that an interrupted cut will still not damage it.
    My money is on silicon carbide whisker reinforced ceramics like Greenleaf's WG300 (or maybe they have a better thing by now). You can get a lot more corners for $200 bucks than a single CBN will give you. Don't expect them to last very long. I don't really believe hyperspeed is necessary on fully hardened steels, either, just so long as you are getting a red hot chip, that's fast enough. Going too fast in very hard steel will still degrade the edge prematurely, IMO. Going ultra fast over an interruption just equals more shock. The hot zone of the cut is interrupted and there is no way around that when the insert crashes into the hole on the other side, it's got to get that hot zone going again.
  21. Likes thanh tam liked this post
  22. #12
    Apr 2018
    UNITED KINGDOM
    2,947
    1366
    Quote Originally Posted by Larry Dickman View Post
    Excuse me ... have you ever looked inside a Pratt & Whitney radial ? Or watched the ballscrews extend the flaps ? There's a ton of grinding on heat treated steel in the aerospace world. That's why there are aerospace procedures for nital etch.
  23. Likes chip_maker liked this post
  24. #13
    Jan 2007
    Flushing/Flint, Michigan
    8,129
    415
    6707
    Get the edge prep right. That means playing with t-land angle and size.
    You are into ceramics, cbn, or very special carbide grades.
    If edge done right even brittle cermets can play in this field also due to their high hot hardness.
    The trick here is at the point of interruption does the tool tip first take the hammer hit or is the hit up on the t-land and into the body of the insert.
    Insane people will try to 3-D model this all out and come up with custom things to try. So much time and energy,
    Sane people will ask their tooling rep for some free samples of edge types available and toss them in the machine.
    And if that's not good ask another vendor for some more free test stuff.
    Often interrupted cuts like bigger lands, higher angles on those lands and almost always negative geometries.
    Bob
  25. Likes thanh tam liked this post
  26. #14
    Jul 2019
    72
    5
    guys like you ,who know TOO much...are a pleasure to read!i learn more stuff just browsing here than anywhere....
  27. #15
    Dec 2019
    South Carolina
    8
    Bob
    Use a low content solid CBN. Hone the edge on a T style. Don’t push the nose forward, use a tool and start on the backside and pull the insert towards you. You can take a deeper depth of cut and you will have 6 edges to use. I can get exact feed/speed in a bit, but you will run it faster than standard turning.
  28. Likes thanh tam liked this post
  29. #16
    Dec 2019
    South Carolina
    8
    Quote Originally Posted by twjames79 View Post
    The low content in the CBN makes it less susceptible to breaking. The binder being cobalt will not be as hard, but it is tougher and less brittle.
  30. Likes thanh tam liked this post
  31. #17
    Jan 2007
    8,129
    415
    6707
    I just want to say Welcome aboard TW,,,,, Or is it James...
    We can always use tool guys.
  32. #18
    Oct 2011
    1,281
    2049
    583
    It would be interesting to get some input from the ceramic tool maker. In the Binns video linked in another thread the (on edge) ceramic tool recipe was described, feedrate, speed, tool approach angle, rake and T-land size with it’s angle rotation to rake face… For a 200hp cut!
    As for grinding being a no-no for aerospace (and a ton of low temp applications). It has its problems, as does any machining if done poorly. Residual stress possibilities and hydrogen embrittlement probability are the biggies.
    Good luck,
    Matt
  33. Likes thanh tam liked this post
  34. #19
    Dec 2019
    South Carolina
    8
    Thanks for the warm welcome. Actual name is Tony Wayne James.... but that’s just too long of an ID to have. Haha
  35. #20
    Jun 2012
    Michigan
    4,830
    4425
    2921
    I'm curious why that is (I don't do aerospace).
