joelsplace
- Jan 31, 2020
I have an Anilam 3 axis controller that lost its config file. I've tried all kinds of settings but keep getting lag over max errors. I'm 99.9% sure that if I had the correct config file it would work.
Could anyone copy theirs for me?
Here's the steps. Problem is you will need a floppy and a computer you can read the floppy on to email it to me.
1) From the main menu select "Setup Utility"
2) Select "Utilities".
3) Select "Copy configuration".
4) Select A: drive and press enter.
If anyone in the DFW area has one I would be glad to stop by and copy it. I'll even make you a backup you can keep in case you lose your config.
Thanks!
Thanks!
