Need G-code parameter list for Weihong CNC controller
Likes Likes:  0
Results 1 to 1 of 1
    Oct 2013
    New Jersey
    1,130
    966
    Default Need G-code parameter list for Weihong CNC controller
    Started my new job and my first project is getting a chinese drilling machine from a company called Bogda that uses a Weihong Lambda 3L CNC controller. Two axis only X and Z. They say it uses 'standard G-code per RS-274' and sample programs were written by a previous employee using only G0 and G1 to drill about 100 holes in a row using 4 drill heads simultaneously.
    I am trying to get a simple list of G-codes and the parameters they require, like you'd use for the Peck drill cycles. Google hasn't found a list anywhere, with parameters only G&M codes. I am guessing because the parameters may be very machine specific. The machine controller is called NC Studio which is pretty straight forward and is conversational but I'd like to be able to directly edit the G-code too.
    My alternative is to write programs with the conversational and see what parameters it puts out in the G-code. simple documentation would be nice.
