I have a solid cast acrylic rod. It is transparent and it needs to maintain most of the transparency after the machining.
The rod is 80mm long and 16mm in diameter. I want to make a hole in the middle. The inner diameter will be 13mm. I don't want the hazy finishing. I need the machined part to be mostly transparent. Flame polishing isn't really an option.
How can I achieve this on my own? What type of machining can achieve the required finishing? What machine should I use? What drill, cutting speed, and feed rate should I use? I have seen some related forums on this topic but none of them are from this decade.
Also, are there any shops in the USA that can do this?
[edit] The hole doesn't go all the way through the bottom. It stops 1.5mm above the bottom. The bottom of the hole has to be flat.
