Need help with boring bar on 640t Fusion control
Likes Likes:  0
Results 1 to 3 of 3
    Feb 2007
    Joplin, MO
    374
    85
    17
    Default Need help with boring bar on 640t Fusion control
    I have a 1999 Mazak quickturn 200 with 640 fusion control.
    I am needing to bore a .316 radius for a ball to fit in.
    I am not sure how to ask it to do this.
    It starts with a .632 diameter bore to .038 deep, then a .316R to a .354 diameter bore at .300 deep, and the straight bore of .354 diameter to .380 deep.
    Any help would be appreciated. I need to get these out by noon on Sunday.
    Michael
    Dec 2012
    Se Ma USA
    2,238
    180
    1218
    You can call Mazak 24/7 IF you have a registered machine (bought from them or registered with them). Some here could tell you, possible even the Mazatrol Kool Aid text. I would not do it without a print. Looks like 3 units of turning.
    Dec 2012
    Se Ma USA
    2,238
    180
    1218
    From my fuzzy memory (maybe)
    BAR IN
    LINE
    ARC
    LINE
    LINE has a start and end point.
    ARC will pick up the LINE end point as a start, so give it the end point. It will ask for radius and arc center. You may not know those at times. So push ? soft key and maybe control will figure it out. But you do know so enter it.
    LINE to finish. Give it the end point.
    SHAPE CHECK to see if it looks right. Maybe radius curves wrong way. Change something.
