Need help with Bspt thread
Results 1 to 9 of 9
    Apr 2020
    UNITED KINGDOM
    5
    Default Need help with Bspt thread
    Hi ,
    Im looking for the starting size and finishing size for 1/2 bspt threads external...
    we are running a rlx protrak 1630, trying to get the thread sizes correct in custom threads but its not working..
    does anyone have the correct sizing for the starting point..
    major dia is 20.955, minor dia is 18.633, pitch 1.814, were cutting the correct pitch but the thread isnt correct in height etc, trying on a new fittings and not working..
    cutting en3b bar...but we have pb bronze to machine shortly...
    any help on sizing would be most appricated
    thanks
    Chris
    Jun 2012
    Michigan
    5,987
    5642
    3813
    Quote Originally Posted by smithy1851 View Post
    Hi ,
    thanks
    Chris
    Your numbers are spot on.What insert are you using? Is it sharp enough?
    Are you cutting a right hand thread?
    Mar 2008
    vacaville ca
    569
    90
    151
    also using 55deg cutter?
    Apr 2020
    UNITED KINGDOM
    5
    Hi
    Yes cutting righthand thread, new 14tpi insert, vardex, brand new only cut these threads, nice and sharp point...
    55' angle, coming in at 27 degrees to make sure insert is cutting on leading edge...
    its just not working and cant see why not...!!
    Dec 2011
    Illinois
    407
    93
    127
    Are you figuring your taper correctly? It should be 3/4" taper per foot, if I'm not mistaken.
    Sep 2010
    india
    1,376
    75
    263
  7. Likes Mtndew liked this post
    Jul 2007
    UNITED KINGDOM
    5,471
    3424
    2820
    Is it a full form insert?
  9. #8
    Apr 2020
    UNITED KINGDOM
    5
    Hi
    sorry for delayed reply.....
    its a Vardex size 3, single point insert ...ive re calculated everything and its still far too tight,
    whats strange too is that the pitch is correct when checked with a thread gauge...
    im now wondering if the insert if wrong..
    having to dig out the coventry die box with chasers to get the job sorted..
  10. #9
    Sep 2010
    india
    1,376
    75
    263
    Starting with a slightly lower OD may help.
