DavidScott
- Jul 11, 2012
- Washington
The lube pump is a Lube co., see the photo below. The problem is ever since I got the used machine 4-1/2 years ago I have had problems with a low-pressure alarm. At first if I kept the tank above 1/2 full it was fine, then I had to keep the oil above 70 degrees. A few days ago it got a lot worse where raising the oil temp to 80 degrees was barely keeping it from alarming out with a full tank.
Side note that may be of importance. I have also been getting a thermal overload alarm 1005 once in a while for the last 2 years. I would shut the machine down, reset the relay, and all was well for a few more months. In the last few months when I would let the oil temp get too low and get the low oil pressure alarm occasionally the thermal overload alarm would go off at at the same time, this has happened 4 or 5 times now.
Control is a Yasnac J300 on a 2001 Kitamura that was not turned off for it's first 9 years so the pump probably has a lot of hours on it. It is a geared pump with an induction motor. Oil is Vactra #2. I put a new filter in the tank pickup 1-1/2 years ago which made no difference. I drained it a few days ago in preparation of taking it apart so that is why the tank is empty.
Any ideas or suggestions about what the problem could be before I take it apart? This is the first time I have taken one of these things apart so I am open to any insights.
