bigjon0123
- Aug 2, 2018
Need help on drilling large holes in 4140: sovled
I’m trying to drill a 1.181 inch diameter hole in 3 inch thick piece of 4140. Currently I’m going center drill, then 3/8, then 1.181 spade drill doing a peck drill. My problem is when I’m running the 1.181 inch drill after about the first inch the chips get stuck in the hole and eventually jams up the drill stopping it from spinning. We can’t do through coolant since our cnc doesn’t support it.
The 1.181 inch drill is running with a feed of .5625, 340 rpm, and the peck depth is .3.
