Need Help! Fanuc Alarm 1400, 607, 613, 9004
Results 1 to 12 of 12
    Jun 2017
    100
    63
    21
    Default Need Help! Fanuc Alarm 1400, 607, 613, 9004
    Machine: 2008 Sharp SV-2412
    Control: Fanuc Oi Mate-MC
    Alarms: 1400 SPINDLE ALARM
    607 X AXIS:CNV. SINGLE PHASE FAILURE
    613 X AXIS:CNV. SINGLE PHASE FAILURE
    607 Y AXIS:CNV. SINGLE PHASE FAILURE
    613 Y AXIS:CNV. SINGLE PHASE FAILURE
    607 Z AXIS:CNV. SINGLE PHASE FAILURE
    613 Z AXIS:CNV. SINGLE PHASE FAILURE
    9004 SPN 1 :INPUT FUSE/POWER FAULT
    I boot up normally, get the 607 and 613 codes, then after maybe 20 seconds a breaker in the cabinet trips and I get the 9004 code. The servo drive has a normal status until the 9004 code trips, then the LED on the servo drive gives ALARM 04.
    Any thoughts on how to diagnose this? I was making chips last night, nothing out of the ordinary. I power up this morning and this is what I get.
    Thanks for any advice,
    Max
    Mar 2018
    Illinois
    39
    6
    Boss man ( my dad whos got more years in this field than I have in life) says those are wired alarms, check the power buss, power supply and all connections. As for the alarm 4 on the drive it may be an over current alarm which would make sense with the breaker tripping.
  3. Likes Max Weber liked this post
    Jun 2017
    100
    63
    21
    Quote Originally Posted by Blakews2217 View Post
    Here's the breaker that appears to have tripped. I haven't found any loose connections or signs of arcing yet.
    Mar 2018
    Illinois
    39
    6
    Id get a clamp meter and see if there is really that much draw on the breaker. Also see into an interlock/ automated trip function. If its got a way to trip that breaker other than pure over current Id check into it so see if/why its doing it.
    As for the alarms, check the main power coming in, verify theres all 3 legs of power, the voltage is right, and connections are tight. Have you had this machine awhile or is the the first time its been powered up in a while? Was it moved recently?
    Jun 2017
    100
    63
    21
    Powered up again... red lights mean somethings wrong?
    Mar 2018
    Illinois
    39
    6
    Those red lights only mean the relay is firing. Not necessarily trouble.
    Jun 2017
    100
    63
    21
    It was the white breaker below the black one that tripped (scared me haha)
  9. #8
    Mar 2018
    Illinois
    39
    6
    Looks like the contacter is closing,but I did not see the breaker trip? The contacter will have a good ca-chunk but it seems it scared you? Is it that loud?
  10. #9
    Jun 2017
    100
    63
    21
    So about 20 seconds after I turn off the e-stop (causing the 1400, 607, 613 alarms) it pops on its own (KM10), which causes the 9004 alarm.
    Does the red blinking\clicking light on KA10 mean anything?
  11. #10
    Mar 2018
    Illinois
    39
    6
    Quote Originally Posted by Max Weber View Post
    The blinking light is telling you the relay is firing. Probably for the alarm light if your machine has the light tree. Id check that power is there on all phases.
  12. #11
    Jun 2017
    100
    63
    21
    The blinking light is telling you the relay is firing. Probably for the alarm light if your machine has the light tree. I’d check that power is there on all phases.
    Phases are good coming out the bottom of the contacts. I'm stumped!
    Also: Here's a video of the sound coming from the servo. I'm not sure if that's a normal sound (or if it should make any noise), but it's sounded like that since I purchased the machine used a couple months ago.
  13. #12
    Jun 2017
    100
    63
    21
    I spoke with fanuc and an independent repair place. They said it's likely to be the resistors on the board that fried. I'll have to keep looking but it seems like I'm going to have to send this off to be repaired.
