Hi, I have a 2000 Fanuc Robodrill T14iaL with the 16i-MA controller.
I have a very perplexing situation that has stumped Tristar, as well as Method machines.. I could use some ideas to Exorcise a ghost out of my machine!
In the beginning. (two days ago...)
The Machine was fine. Yesterday, I loaded a program onto it using a Fanuc memory flash card (used many times) It loaded fine, written to O0001.
Immediately after that I navigated to load the program all OK till I pushed the "AUTO" button. The "930 CPU INTERRUPT" screen popped up and locked up the machine!
I shut it all down and restarted it. Everything was OK but as soon as I pushed the "AUTO" button BAM!! 930 again! I tried a few more times, as well as navigated all over through the system with no problem.. But as soon as the "AUTO' button was pushed the wheels came off.
After a few times of doing that I get a "750 SERIAL LINK ERROR" alarm! at this point it seems the sky is falling.
I was suspected that every time i pusher the "AUTO" it activated the SRAM to pull a program.. Soo I re-flashed the SRAM to my backup. That actually worked! Now I could push the "AUTO" and it all worked without an issue (except the 750 was still there)
I went to load a different program to the machine. I noticed in the DIR of the machine programs that the O0001 program was still there after a re-flash, but it was the number only, the name was gone and it was totally blank. It would not delete. I did however overwrite it then deleted it. WEIRD
So now I have a "750 Spindle serial Link" alarm aaaand now a interesting turn of events. The "OFF" button on the panel doesn't turn the machine off!? But the "CYCLE STOP FEED" button will shut the machine down as if it was the OFF button!! BUT only if I try the actual "OFF" button FIRST, then try the FEED STOP button.
I'm left with currently:
- 750 Spindle serial link alarm
- OFF button does not shut the machine off
- Cycle Feed Stop button will shut the machine off as if it were the OFF button if I attempt the OFF button first
Extra info:
The Spindle AMP LED is blinking "- -", with no AL code
All the other AMPS are readied up and able to be moved in MANUAL mode.
Things I've tried:
Used contact cleaner on the Spindle amp cable connection male and female.
Called it names.
Stared at it menacingly.
Called TRISTAR to no avail..
Called Method Machines to no avail..
Now I'm begging for insight from you all..
thanks
Extra info:
Things I've tried:
Called it names.
thanks
