Hi All,
So I've been hunting around for a super cheap ($500) fixer-upper/retrofit CNC machine for a few years now and finally pulled the trigger on a Moog MHP T-24(not even sure that's the model #) sight unseen. I figured for $400 (including 40 tool holders) I can't go wrong in any way, even if I end up scrapping and parting it out.
I can't find any information on this particular model anywhere. This machine seems to be based off the Bridgeport Series II frame with boxed ways. I have not been able to find any other machine like it. Most out there are based on the Series I frame (S-24) or the larger machining center style frames (B-22).
When I arrived to inspect the machine for transport I was pleasantly surprised. The machine seems to be in great condition. The ways look pristine, didn't have time to check ball screws, which is what I'm assuming this machine has. After speaking with an employee I was told that this machine had just been setup for an upcoming job and was in perfect working order with the exception of the tool changer solenoid, which apparently sticks when cold.
I wasn't able to inspect the electric cabinet as it was locked. I am hoping the manuals are in there.
Any information about this machine would be much appreciated. After a few hours of research I can't even verify the model #...
Some other info for those interested:
Hydra-path III controls
Moog Hydra-point taper (never even heard of this before)
24 position tool changer
Flood coolant
13-1/2" X 42" TABLE
PNEUMATIC DRAW BAR
ONE SHOT LUBE
POWER QUILL
S/N: 27012
Thanks!
Flood coolant
13-1/2" X 42" TABLE
PNEUMATIC DRAW BAR
ONE SHOT LUBE
POWER QUILL
S/N: 27012
Thanks!
