gear cutter
Cast Iron
- Oct 16, 2010
- MO, USA
I am having trouble machining some parts from 304SS. The part is 1.062 OD X 2.06 inches long. I need to machine a bore .875 ID X 1.875 deep with a boss at the bottom of the bore at the bore center. The boss is .280 OD X .437 long. I have drilled and bored to the finish ID up to the face of the boss. Then i have tried to mill the material away around the ID of the bore and the OD of the boss. I am not doing something right here. All I am doing is breaking endmills. I am machining the parts on a Okuma Genos L 200 M with live tooling. The endmills are accupro .250 OD with .500 flute length and factory relieved shank. I have 100 of these to do. Any help would really be appreciated. Thank you. Tim
